fuse location
billdad
My cigar lighter does not work and I suspect it is a fuse issue, Also, the display which is supposed to show the temperature (located below the radio) shows nothing. 😕
Are these both related to fuses? Where are the fuse panels located for these?,
The forum has helped before, and I am hoping it will again🙂
Don't know what car you have, but on my '94 it's under the dash a little to the left of the steering wheel.
The owners manual will have that info in it. Google it, with the year of car, make, the model and "owners manual."
Not sure which vehicle you have, on my '95 Ultra there is an underhood fuse panel, a fuse panel left of the steering column down by the pedals, and another fuse panel underneath the glove box on the passenger side. Should be in one of those!
Does your HVAC (heat controls) work at all? If the blower fan is inop and the controls don't work, you may have a fuse problem or no power going to the controller. If the display is out and your controls still work, the problem is the HVAC controller itself. Good luck Bill!😉
