Headlights stuck on high beams??
Ashbot
Taylorsville, GA
2000 Buick LeSabre Limited
Hey everyone,
New poster here. I own a 2000 Buick Lesabre LTD, let my mom borrow it over the weekend and she somehow got the headlights stuck on the brights. The arm has been touchy since I bought it, but since I personally do not use my brights often, I never had a problem with it. Now I cannot get it out of that position. Any hints on how to fix it without replacing the entire multi-function switch?
Thanks,
Ashley
You would still have to remove the same pieces to fix it as to hit the internal part to switch back. The steering wheel will most likely have to come off.
headlight switch on a 2001 Lesabre limited can be remove by just removeing the airbag and then you can turn the steering wheel to get the screws out through a hole in the steering wheel .
