Heat on drivers side...cold on passenger.?
SunniDee
We have a 2007 Lucerne. We are getting heat on the driver's side and cold air on the passenger's side.
One mechanic told us he thought the actuator was ok but is not opening a little door to let the heat get to the passenger's side. Does this make sense? Any one know how to get to the little door? Any other ideas on what to check?
Thank you so much!
I had this problem on my 2000 LeSabre; I am sure the mechanism is similar in my/your Lucerne.
I really don't understand how the actuator could be functioning and yet not open the blend door. Perhaps the door itself is jammed, or the connection from the actuator to the door is broken. Again, I am sure it is the same in the Lucerne, but on the LeSabre, I had to take the passenger foot panel off and take out the glove box if I remember correctly. I don't recall it being particularly difficult, just hard on the back and knees.
My driver side actuator has the same symptoms on my 03 LeSabre. Anyone know what the R&R cost to fix? I know where the unit is, but need instrux how to remove dash pieces to get there.
Also, refrigerant leaked out of system. Shot it with a can of coolant. Was cold on pax side only then eventually leaked out. What am I looking at here to fix AC?
Thanks.
I had it on my 98 park Ave. Spent. Tons of time and money to fix. The only thing that worked was disconnecting the battery for 5 minutes and put back on and it would work for a week. They replaced sensors. And actuators. You name it. I sold it and was still broke. Good luck man!
SunniDee:
This cold/hot problem happened on '90s Park Ave and '00s Park Ave that we owned. Yes, it's an actuator/blend door problem.
I chose to have a qualified mechanic repair each car and IIRC the costs were a little under $300 each time. I'm not able nor flexible enough anymore to bend into a pretzel to work under the dashboard like polarzak.
So far, our 2006 CXL is working just fine.
57finz:
You have multiple problems: blend door and system leaks. Seek professional mechanical help before it gets hot outside!
If the driver's side temperature does not change when temp control buttons are adjusted, the Lucerne's driver's side blend door actuator is the issue. This actuator can be replaced WITHOUT removal of the dash.
To access the actuator, remove the plastic panel below the steering column (remove 2 screws and panel snaps out by pulling panel straight up towards steering wheel). Once this first panel is removed, the kick panel above the accelerator and brake pedals must be removed (panel is secured with 2 plastic barbed pins, which can be pulled or pried off). Be careful when removing this kick panel, as there is a lighbulb connector that must be unclipped. Also pay attention to how the right side of the panel hooks into the heat ducting, as this this connection must be reattached during reinstall of panel. Once kick panel is pulled off, the small plastic panel on the right side of the accelerator pedal must be removed. Panel is clipped into center console with 2 clips. Pull panel straight off (pull in direction of driver's side door). Now that all panels are removed, slide driver seat all the way back and lay on your back with your head near the brake pedal. You will need a light and a stubby Phillips screwdriver to remove blend door actuator. Actuator is mounted against the airbox (the large black plastic box located directly behind radio). Make sure that you don't confuse the blend door actuator with the recirculation actuator. The blend door actuator has a white plastic lever, whereas the the recirculation actuator has a metal lever.
To remove the blend actuator, there is an air duct in the way. This air duct has a round clip on the top, which secures end of duct to a metal tube. The duct can be disconnected from metal tube by unsnapping clip, which allows duct to be pushed out of the way just enough to reach up and reach actuator mounting screws with a stubby screwdriver. Actuator is held in place with 2x screws. Make note of the orientation of actuator and wire harness BEFORE removing actuator. Remove both screws BEFORE attempting to disconnect electrical connector from actuator. Once screws are removed (this requires patience), the actuator comes right off and the electrical connector can be unhooked.
Connect wire harness to new blend actuator and re-position actuator into its correct mounting position. Warning, do NOT rotate the white actuator lever, as this will damage the actuator. Note that the wire harness must be run on the visible side of the actuator. The actuator has two screw holes for mounting, and 2 holes that align with plastic guide pins on the airbox. At this point, do not try to connect the actuator’s white lever to the corresponding lever on the airbox. These levers are much easier to connect once the first mounting screw is partially installed. Install one mounting screw, but only thread screw in about 2 turns. Once screw is started, pivot the airbox lever until the slot in the airbox lever aligns with the pin in the white plastic actuator lever. (Do NOT rotate the white actuator lever, as this will damage the actuator). Once the levers are connected, push the actuator against the airbox and install the 2nd mounting screw. After 2nd screw is installed, go back and tighten the 1st screw. After screws are installed, the actuator installation is complete. The air duct can be snapped back onto the metal tube.
When reinstalling the kick panel, be careful to ensure that the panel attaches correctly to the air duct. There is a guide lug that slides inside the duct for alignment. Also ensure that rear of kick panel is mounted securely above brake pedal arm, and ensure that panel does not interfere with brake arm motion.
Once panels are reinstalled, the blend door actuator must be recalibrated. This can be accomplished by turning key to ON position, without starting car. Wait 3-5 minutes, during which you may hear actuators clicking as they self-calibrate. After 3 minutes, remove key and then car can be started normally.
I had a similar problem recently, but the sides were the other way around. The passenger side was working properly, but the driver side was messed up. No matter what the temperature setting was set to, it would always blow the air in from the outside without any temperature change.
I took it to the dealer. They said that it was a thermostat issue. They had to tear out the dashboard, replace the sensor, and put the dash back in. $1100, most of it for labor with the dashboard. The temp sensor was about $100.
And add to that a $300 'cleaning fee' that I was not allowed to decline. If I did not want the car cleaned, they would not do the work. Total about $1400.
George Carlin once said: "think about how stupid the average person is, and realize that half of people are stupider than that."
BTW, this thread is 10-yrs old!
Thank you so much!
I am having the same issue. Also, Mechanic told me it is the heater core box. Apparently there’s a wire there that says the signal and it’s not sending the right signal cause it’s damage. I don’t know. At this point. I might as well just change the heater core as well. It’s in the same location.
