TooBadItsNotAGS
- Mar 12, 2015
- Michigan
- 2002 Regal LS
I was changing the brakes on my 2002 Buick Regal LS and I took everything off like it was supposed to. Then I went to go put everything back on, but the rotor was loose. I looked around and discovered that it's fairly normal. I proceeded to put on the wheel, but the lug nut posts weren't coming through the tires far enough, which caused me to not be able to put on the tires all the way. I took all the new stuff off, and put the old stuff back on. Problem still persists. Any suggestions? I've never seen this before..
