HID Retrofit
abdomega
2005 Park Avenue Ultra
I decided to upgrade the headlamps on my 2005 PA Ultra. This was the first retrofit I've done and it was a challenge to say the least but after I did the passenger side, the driver side was much easier.
Instead of using the headlamp housings on the car, I swapped out for an OEM replacement I bought on Ebay, went about opening them up and commencing with the retro. The kit installed is the G5 D2S Bi-Xenon Projector Retrofit which I purchased everything from Lightwerkz. All in the cost was just under $600.
Thanks for looking!
PXL_20251221_111410726.webpPXL_20251119_193853102.webpPXL_20251119_193848218.webpPXL_20250824_193746875.webpPXL_20250824_193758789.MP.webpPXL_20250824_193802169.webpPXL_20250824_193811347.webpPXL_20250825_202452361.webpPXL_20250825_210116973.webpPXL_20250913_185209119.webp
I have some familiarity with your challenge. I have a 2011 Malibu that I tried to retrofit with HIDs. It was more than I was able to manage after just one, so I cut my losses, bought a housing, and swapped to LEDs.
On my 2005 LeSabre, when I turn on the high beams, the stock circuitry turns off the low beams. My Malibu did/does not do that. I would need to ensure that the LeSabre's low beams stayed on anytime the headlights are on, then add the high beams.
