How to remove pushrods? 3.1l v6
84baritz
1996 century custom, 1998 park avenue
Ive taken the engine apart on my 96 century because the intake gasket went, and in order to put the new gasket in I need to remove the pushrods. I bought a special tool off Amazon that lifts the rocker arms so you can take the pushrods out, and it worked for 6 of them, but the other 6 didn't work, the rocker arms wouldn't lift far enough. I'm kinda stumped now, and I'm taking a little break from it for the night. Anybody have any suggestions?
Did you rotate the engine assembly to get the valves in the close position?
Sorry for the late reply. I ended up just buying a new torque wrench so I could take the rocker arms off, but I should have tried turning the crank instead. I found out after I had put the engine all back together that it's seized. Kind of a bummer, I'm just going to look for a lower km engine now as I don't want to completely rebuild the engine. Thanks for your reply though
Hopefully you will be able to locate one a good used one, to bad on your current engine.
