I just bought a '93 buick Roadmaster
humblebwonderful
Nomad
'93 Buick Roadmaster
Hey friends! i just bought myself a 93 roadmaster, and I gotta say, I really like this car. Mines got a fuel inj 350 engine and posi rearend, a flowmaster exhaust, aaaand a sweet soundsystem. One little thing though, it has a little trouble starting up sometimes. it takes 3 or 4 seconds. It's never not started up but it kind of concerns me as i'm about to drive down the west coast and over to texas in thin thing. I'm a girl who doesn't know a whole lot about cars, except for this one is a tank, and i'm wondering if you guys might have any ideas what might be going on? Is it the weather? Filters? Plugs? Bad ju-ju? does your roadmaster have this issue? is it just because its almost 20 years old and nothing i shoul worry about? I'm going to take it to my mechanic friend before i hit the road but i just thought i'd ask your expert opinions. Love and light folks.
Welcome to the forum and congrats on the new Roadmaster. 🙂
There could be a number of things that causes your hard starting. When I first bought mine it was a bad starter. It could be anything from a weak battery to a bad connection to perhaps a fuel filter. There are more knowledgeable guys on the forum that might give you some more ideas. Certainly get the car checked out thoroughly before starting such a long trip.
I'm a girl who doesn't know a whole lot about cars ... It's never not started up but it kind of concerns me as i'm about to drive down the west coast and over to texas in thin thing.
Chances are you have no mechanical history of this car.
Simple things make a big difference. I'd start with changing the fuel filter because there is a chance that it never has been changed. Nimrods drive cars too, and that means gas & go maintenance. Change your air filter too, that's a long trip.
3-4 seconds is a long crank, and it probably is not that long (not doubting you, it's a time perception thing that most people have)
Simple things a young girl can do to help herself and impress others .... open the hood at night and remove the under hood light bulb. Now that it's nice and dark start the car up and look for sparks ... light blue arcing type sparks. Listen for ticking sounds and try to look at where the sound is coming from. If you see sparks you need some wire management ... namely replacement.
Speaking as a father here, actually a grumpy old man, I would have the fluids changed out before allowing my daughter to drive this car around such a long way from home. That means oil, coolant checked, trans fluid changed, power steering fluid checked and the differential checked. (that should be done with the oil change) Also, have the front end inspected for excessive play and wear.
Tires ... look for excessive wear, dry rot and signs of the belts separating. Have those brakes looked at too. Tires and brakes are without question the most important parts of a car. It does you no good to go if you can't steer or stop.
Any signs of leaking fluid should be addressed. Can't afford it? You can't afford the trip then!
Hoses, belts, and the wiper blades. (Avoid Quick Lube joints as they jack up the price on filters and blades to unrealistic retail prices!)
Now get your butt back in the house and clean your room young lady! 😀
Enjoy your trip and be safe!
PS ... these cars haul and speeding is easy to do ... a modern and updated GPS unit will warn you of speed zones!
We expect pics of the car and trip!
BTW ... did you know that you can access this site from your smart phone?? Might be a good idea to bookmark it on your phone.
Good choice. I bought a '93 RML a few months ago and both my wife and I have fallen in love with the beast. Smoothest car we've ever owned...and I'm talking from everything from a 300E Mercedes to a Oldsmobile Aurora to a Corolla to a Tahoe. The 350 is just a great engine. Frankly, since you may not have a maintenance history and you are about to embark on a trip it may be worthwhile to either do a tuneup yourself or have it done. You may actually save yourself some money in increase performance and hence gas mileage. Plugs, plug wires, oil, filter, gas filter, air and injection system "preventative maintenance", etc. May save you big bucks and heartache in the long run. My two cents worth.
