arestavo
- Oct 25, 2025
- 2011 Buick Lucerne CXL
Hey all. I was very lucky to inherit a 2011 Buick Lucerne CXL with just over 20,000 miles on it from my Grandparents (making me the second owner). My grandfather's ham radio call sign was WA8PRK for anyone who might be an enthusiast.
This Lucerne is almost pristine inside and out. A scuff mark on the front bumper and on the driver's side passenger door (and that's why I always park in the way back), and two small black marks on the driver's headliner (I haven't tried using a cloth with water to scrub it yet - Grandparents were not smokers). Leather interior, power seats (not heated), heated steering wheel (not wood), column shifter with the 6 seat option. It does have backup sensors, but no nav system (yay for cell phones!), and the standard CD / XM radio deck. Yes, it has the original sticker in the glove box.
I drove it up from Arizona where it was garage parked, to Idaho where it is also garage parked, after getting it checked out at a Buick dealership and a new battery and an oil change. I've been reading through the entirety of this forum for the 09-11 year Lucernes, and I just wanted to make sure that I've correctly found out what to look out for / be aware of.
- Oil changes. Keeping up on them and the 3.9L 3900 (while not a gen III 3800) will treat me well. I plan on every 3K miles or once per year for oil changes, whichever comes first as I don't drive much anymore, and now it'll be mostly town/city driving (thankfully no more 120 miles a day, 5 days a week on a highway with a Ford Focus that has its TCM fail multiple times). Small engine oil leaks may be solved with stop leak such as ATP AT-205 once they start, which is not yet the case.
- 4T65E transmission. With just 22K on the odometer, should I just get the transmission fluid drained and changed (not flushed) and the transmission filter changed, or should I wait? I looked through the paper records and didn't see a transmission fluid change anywhere. Yes, I'm worried about the glass 4T65E and it not engaging gears. However, I could just be a bit paranoid since my Ford Focus (now sold) had so freaking many transmission issues.
- Power steering fluid reservoir. While mine currently looks fine, good luck finding one for an 09-11 Lucerne if something happens to it. Junk yard only at this point, if you're lucky enough. Though I've found plenty available online for the 4.6 Northstar engine. Originally I did have a bit of a whine when turning the steering wheel, so I topped off the fluid (ACDelco GM Original Equipment 10-5074 Power Steering Fluid) as it was a little low and now the whine is almost gone except a little at the very start of the wheel turn (left or right).
- Fuel pump relay. I replaced that with an aftermarket low profile relay and I keep the original in the glovebox, just in case. No signs of burn marks or overheating, and I've bent the driver's side bracket inward enough to prevent the relay burnout issue, as opposed to cutting the ends off. Not that I often have anyone in the back seat.
- Headlights. No need to drop the bumper like the stealership wants. Pop off the front wheel well flaps and swap bulbs that way in a 10 minute job. Maybe I'll use LEDs when I have to replace a burned bulb? I assume that they are all original, and adequate for now as I don't drive much at night. The additional side lights that engage when turning are pretty neat.
- Car battery. In Arizona it had to be replaced quite often compared to what I'm used to up here. I did check Napa and O'Reilly's auto parts, yet it doesn't seem that they carry the side terminal style batteries. Just ones with the terminals on top that show as compatible with the '11 Lucerne. Is that BS, or will it actually not be a problem?
- External door handles. They apparently like to break, yet are somewhat easily replaceable by those with some time.
- Rear air shocks. Probably cheaper (~$700 for parts) to do the conversion once they go out. If the car self limits to 80MPH, that's a sign that they are going out - pulling the fuse(s) for them can restore speed.
Did I miss any common issues that I should be aware of? Thanks, John.
