Brian Atom
- Aug 2, 2024
- 2005 Lacrosse CXS
I changed the oil in my 2005 Lacrosse CXS but didn’t reset the reminder. The second warning is all the warning lights came on and the message says to shut down the engine immediately. I did that then I was unable to turn the key all the way or restart the engine. A while later it started but all the instruments were dead including the odometer. Also the battery drains after about 8 hours too. The battery is good I disconnect it every night and it has been like this for months. Can I remove the cluster to have it repaired and still drive the car? Also if I find a cluster used can I correct the mileage? Hopefully the cluster is the battery drain problem as I pulled every fuse and didn’t find the problem that way. Thanks
