So I disconnected my aftermarket stereo but did not connect the factory. The issue persists though. I figured I didn't need to plug anything into the radio wiring harness to test.
Regarding the door issue, wouldn't that only be the case if that was the only door doing that? No matter what door I open the dome/reading light does not turn on.
I have a regular Bluetooth odb2 reader and torque pro but there aren't any faults found.
Is there a way to test the fuse box issue 2007lucernCXL mentioned?
I had this issue before after replacing the dome like bulbs and accidentally shorting the wires. What it was was blow the fuse, and in 2006&2007, the interior light dimming circuit had a shared fuse with the front right turn signal.
However in 2008+ it had its own fuses. For your vehicle it would be fuse 35 and fuse 32.
Something else I should note is that just because a continuity meter says that it is good, doesn’t mean it is. That’s what screwed me up, I thought I had fried the BCM, but it turned out the meter was giving a false reading because when I pulled the fuse out I could clearly see it was blown inside. That is something I would check.
If both 10a fuses are good, you will then have to go to the BCM and check to see if there is voltage going to Pin #2 on the X3 & X4 connector, if there is voltage, it’s possible your BCM may be fried, otherwise there could be a break in the wire from the fuse block to the BCM, or the fuse is bad/blown.
Hope this is able to help a bit, I understand the frustration.
