TheBude
- Jan 6, 2020
- 2001 Century
2002 Buick Park Avenue (N/A). 140k miles. Parts recently replaced in the past two months
All of the park plugs
1- coil pack
Ignition Control Module
Catalytic convertor
Cleaned IAT, MAF (replaced 1 year ago), IAC valve
Checked starter with battery, jumper cables and screwdriver. Starter works well
Cleaned grounds at the transmission housing. All other grounds are tight and clean.
Once started the car seems to run fine other than slightly rougher idling than prior to this issue (post title) that began a few days ago
A year ago I had similar issue minus the battery click/starter not cranking. A new MAF sensor fixed the stalling after starting issue so. I don't think it's the MAF sensor. I don't like throwing parts on without testing. Google search leads me to the following items as possible suspects.
Crank position sensor
Camshaft position sensor
Powertrain control module (PCM)
Wiring harness break or other issue
All replies appreciated in advance.
1- coil pack
Catalytic convertor
