TheOmen86
- Jan 25, 2025
- 2006 lacrosse cxl
So I have a 2006 lacrosse cxl that has never gotten up to operating temperature the couple years I've owned it. I replaced the thermostat 3 or 4 times and the coolant temp sensor 3 times. The heat works but it's not "hot hot" has to be set at 90 to really even feel like heat. I changed the coolant and crudely checked the gauge accuracy by checking live data and using a laser thermometer thing pointed at the engine. It doesn't get hotter than 171°F in the Pennsylvania winters the p0128 code stays on for coolant temp heating up too slow. The fuel economy is also not very good either. Around 16mpg highway on average. Maybe that's just how crappy it is tho 😂 I'm now in up state new York and it's been a sweltering couple weeks with temps in the single digits and below zero. It is now staying at the 25% mark and doesn't go any higher. Usually in normal pa summer temps it gets up to 3/8 at the most. Idk what else to check. Engine runs super smooth and quiet. 99k miles. Also the previous owner rear-ended a SUV causing minor plastic damage and crushing the hood latch. Nothing hit the radiator from what I can tell. when I wrote this and took the picture It's been idling for 40 minutes. And the outside temp is correct at 21°. Thank in advance for any advice.
