Leaking Front and Rear Struts and Replacement Options - 2019 Regal GS AWD
rolln2low4u
Original owner of a 2019 Buick Regal GS AWD. I was inspecting my brakes over the weekend and realized that both front struts and the left rear strut are all wet appearing that they are leaking. Of course way past warranty so need to replace. I am not seeing anything on the web about an issue and only see directly GM OEM replacements for crazy amounts. Is anyone aware of other options than the GM OEM struts. Any guidance is very much appreciated.
Since you have real time adjustable shocks it does not appear the aftermarket has provided any options due to the low production volume of the GS. I just looked at Rockauto which usually has multiple options and they only showed GM.
It also appears some of the struts are on backorder which is not a good sign of availability.
I had a 2017 GS and started looking at the availability of struts and brake calipers and decided to sell the car before I needed those and other parts that were no longer available.
