Adjusting Fuel Trim for Optimal Performance
To adjust fuel trim for optimal performance, you may need to replace a faulty MAF sensor if that’s at the root of the problem. After installing a new MAF or even a stock MAF, it’s essential to reset the ECU to allow the system to recalibrate itself. You might also want to check the air filter and all hoses connected to the MAF to ensure there aren’t any leaks or restrictions. Regularly monitoring your fuel trim can help you catch issues early, enabling a better experience behind the wheel.
......the above was from a Google search regarding MAFs and fuel trims.
