On my 2017 buick envision premium 2 when front max defrost button pushed it lights but no function.can any one help
NoDoes fan speed increase ?
Has function but fan does not ramp upOn my 2017 buick envision premium 2 when front max defrost button pushed it lights but no function
Dealer says it's functioning as designed?Has function but fan does not ramp up
Took to another GM Dealer for diagnostic they say has max defrost but fan speed does not increase as owners manual says he will call local GM field engineer that was already involved in previous repairYes customer service says my vehicle doesn't have this function this all started after dealer replaced rear evap case blower motor climate control panel and climate control module
No GM service engineer said its a programing issue, awaiting responce from GM. I personally think the dealer that replaced the ac evap case screwed up the wiring.Did you ever figure this out? My 2015 lacrosse is doing the same thing.
No, a month ago my collision alert became significantly louder, as did the beeping when I first get in before I put on my seatbelt. It doesn’t consistently respond to the Chime Volume either. And yesterday I noticed the max defrost button doesn’t turn up the fans. So idk what’s going on.Did you have any work done on the AC system?
I would check the blower motor resistorNo, a month ago my collision alert became significantly louder, as did the beeping when I first get in before I put on my seatbelt. It doesn’t consistently respond to the Chime Volume either. And yesterday I noticed the max defrost button doesn’t turn up the fans. So idk what’s going on.
2015 Lacrosse V6 FWD
Where is that?I would check the blower motor resistor
The resistor is under the dash near the heater, sounds like all electrical problems!Where is that?
I also just noticed the Maximum Startup Volume isn’t working anymore…
False alarm on the startup volume, I just didn’t wait long enough for the car/radio to completely turn off, I guess.Where is that?
