giorgio66613
- Dec 3, 2013
- Phoenix, AZ
- 1997 Buick Park Avenue 3.8l
Hi Everybody,
I need some information on the oil pump on my 1997 park avenue. Oil light remains on after doing the reset test but after looking at the engine info I found that it tells me that oil pressure is at 0psi. I then took off the oil cap and found the upper end bone dry. Oil change was done so there is the right amount of oil in the car. So I was gonna change out the oil pressure sending unit but I'm pretty sure that its the oil pump that kicked it. So I wanted to know if anybody has had the same problem or if they know where the oil pump is located so I can buy the repair kit and fix it. I would also appreciate some insight on the procedure of installing the repair kit. Thanks I greatly appreciate it.
