movs
- Aug 12, 2009
- Ottawa, Ontario
- 1994 Buick century wagon
Hey all
I'm new to buicks and i'm having a hard time understanding all the electronics that make that car works properly!!
I tried different places to get answer for my problem but i just cant get a good straight answer to get me starting!
first off my grand-pa gave me that car last year and it was working well. i did notice that it would bogg a little bit when going up hill before it would downshift but it was easy to get away with it....now i parked the car for the winter and i got it out 2 weeks ago. the battery was dead and it would always stall after like 2 min. SO i put in a new battery and it help a bit. i thought it needed to be opened up to clear everything out so i took it for a ride. i couldn'T stop else it would stall so i just kept going and it bogg alot on take off and whenever it would hit overdrive so i constantly had to make it downshift. on my way back it started to backfire in the intake and it did have enough power to climb a 3% hill and it was bogging HARDCORE.😕
I parked it changed the plugs and wires, removed and clean the trottle boddy assembly and put everything back in. Now it idles for like 20 min without stalling and i can put it in drive or reverse in that period without any problems. after that it will slowly bog down and stall unless i rev it a bit higher. The check engine will come and go at random periods. I beleive there'S somekind of a heat sensitive sensor or something that causes that issus but i don't know what it is!!!
I also noticed that when it's about to stall and i give it gas there's black smoke coming out the exhaust like if it was running too rich at idle and then it goes back to normal????
Any input from someone who had a similar issue or anything to put me on the right track would be AWESOME.
I also noticed that when it's about to stall and i give it gas there's black smoke coming out the exhaust like if it was running too rich at idle and then it goes back to normal????Any input from someone who had a similar issue or anything to put me on the right track would be AWESOME.
