Sam14GS
- May 15, 2014
- Lake Worth, Florida
- 2014 Buick Regal GS
Installed new LED lights today. White during the day and light blue when the headlights are on. Might not keep the light blue, will leave it for a while. It didn't come with mounting instructions.
The back of the light had small tabs so I assumed the small grill had to be removed which I didn't do.
I came up with an idea to some how adhere two bolts to the back of each light so they would go through the small grill, then put a small washer and nut to hold it in place. The back of the light is a plastic/smooth rubber material. I sanded the back to roughen it up and tried JB weld which did not stick to that material. Also tried one made by Loctite and that failed. Finally got it to stick well with Shoe Goo 😵
I added a waterproof connector, just in case the bumper has to be removed.
Used two diodes to isolate the two power connections to avoid any possible back-feed.
I didn't want to cut into the headlight harness for the connections. Instead, I went into the fuse box and used #54 for the ignition source and #49 for the headlight trigger (didn't connect amber turn signal). Used a bolt next to the fuse box for the ground.
Continue next message....
