Incorrect. I suggest you consult your owner’s manual (Pages 3-17 through 3-19 on 2005) or a shop manual wiring diagram. The interior lighting (dome lights, door lights, various courtesy lights) is controlled by the sensor in the center of the dash, as well as the exterior lighting including headlights:
Courtesy Lamps
If it is dark enough outside, when any door is opened, several lamps go on. They make it easy for you to enter and leave the vehicle. You can also turn these lamps on by sliding the INTERIOR lever all the way to HI.
Entry Lighting
If it is dark enough outside when you press the unlock button on the remote keyless entry transmitter, the interior courtesy lamps will turn on and stay on for about 40 seconds. The lamps can be turned off immediately by pressing the lock button on the remote keyless entry transmitter, turning the ignition key to RUN or activating the power door locks.
Delayed Entry Lighting
The interior lamps will turn on if you open the door when it is dark enough outside. When you close the door with the ignition off, the interior lamps will stay on for up to 25 seconds or until the ignition is turned to an on position. When the lamps turn off as a result of the 25 second timer or the ignition switch being turned on, the lighting will deactivate by way of the theater dimming effect. Locking the doors will override the delayed entry lighting feature and the lamps will turn off right away.
Theater Dimming
This feature allows for a three to five-second fade out of the courtesy lamps instead of immediate turn off.
Delayed Exit Lighting
If it is dark enough outside when you remove the key from the ignition, the interior lamps will turn on and stay on for about 25 seconds. This will give you time to find the door pull handle or lock switches. Once the key is inserted into the ignition, the exit lighting will be cancelled and the lighting will fade out. Perimeter Lighting If it is dark enough outside when the unlock button on the remote keyless entry transmitter is pressed, the DRL, parking lamps and back-up lamps will come on.
The phrase
“If is dark enough outside,” is in there because all of this is controlled by the
ambient light sensor. Driven Daily seems to have a one-off Lesabre in several respects, so not sure what is going on with that. I believe he has also said his washer bottle is on the driver’s side, which certainly makes it a one-off version or some kind of special factory custom.
