No power to rear driver-side door
spon
Bad eMail Address
California
2000 Buick LeSabre Custom
Last week, I used the key remote to unlock my car. but the Rear Driver side door did not unlock. I checked the other 3 doors and they all lock and unlock with the remote. I also tried to door lock/unlock switch on the driver door and passenger door. That worked too. I had to manually unlock the door, and it opened. then close the door and manually lock it.
In addition, on the way home, I tried to roll down the Rear Driver side window. and nothing happened. it stayed in the up position. I remember that morning I had opened the window and closed it. THe other 3 windows roll down and up without problem.
I don't know exactly what to do or what I'm looking for. Suggestions from this forum are check the fuses and check the wiring under the driver seat for moisture (spilled liquid). Is this where to start? Any other suggestions?
THanks.
the wire harness in the rubber boot connecting the door to the body of the car
I looked at this boot, there does not seem to be any damage to it. Any other suggestions?
not the boot itself, the wires in the boot that are constantly being bent every time the door is opened and closed.
