JuanMFc15
- Sep 18, 2019
- 2015 Buick Encore
I have a 2015 Encore that's leaking oil fast, I haven't been able to find where it leaks from, I think it's coming from the area around/above the Left side of the engine, because of The belt movement the oils is everywhere on that side, recent work done, New water pump and new cam position sensors (both), it can be the oil pan Because the leaking starts from much higher and valve cover looks dry, no oil around it, no check engine lights, no codes, however a few days ago a "knock sensor code appear but it disappeared by ir self... I'm running out of ideas and I'm afraid to take it to the dealer and end up being charge for 90% of the engine replaced before they actually find the leak, please help!!
