You are from Mars as your knowledge is OUT OF THIS WORLD! Massive respect!
A while ago, you responded to a post regarding transmission fluid change. You suggested replacing the W shaped "clips" at the four ends of the transmission cooler lines (at transmission and at radiator). I ordered the GM cooler lines BUT on your suggestion to replace the "O-rings" presumably inside of the cooler line connectors, I simply cannot find any data relative to where to source those O rings. In the past (2020) a post was made by someone who used Spectra O rings and felt them to be poorly fitting. I don't want that drama. I'd just like to have either a bag of new O-rings for the insides of all those connectors, or, new OEM connectors and be done with it.
Any intel on the OEM O-rings (part numbers) you suggest are one time use, or, the OEM connectors (P/N's) for their 2005 LeSabre Custom?
Thanks in advance. Might as well as you since you are clearly the font-o-knowledge on all things "Buick." Appreciate it.
