Bill G. Johnson
- Jun 20, 2024
- 2017 Verano
I am rebuilding a 2.4l Ecotech. It jumped time and took out 7 valves and three pistons. I replaced the pistons. And new rings. Yes I clocked them. The pistons are going in the right direction. But I was un sure of the connecting rod orientation. A "mechanic" told me about chamfers on the rod caps. But My eyes are not that good. I see that there is printed letters to match up with the rods and caps. It's also on the same side where there is the grooves for aligning the rod bearings. A "mechanic" told me that they face out. Towards the intake side. But I just watched a video of a 2.4 tear down from a Terrain that shows it point towards the exhaust side. Does it matter? I put on a remanufactured head and put all the timing and secondary chains and guides in. Everything lined up with the colored links on each chain with the marks on the corresponding gears. How ever, when I installed the engine and tried to turn the engine over with the crank to line up the flywheel to the torque converter, it wouldn't budge. I'm afraid that I will break the crank shaft bolt. Is it possible that the connecting rods being on backwards is causing this?
