aroethli
- Jun 7, 2008
- Buick
I have a 1995 Roadmaster sedan, with about 160k miles on the clock.
About a year ago it started to occasionally miss when the engine was under a light acceleration load. This has now become much more common once the engine is fully warmed up, such as idling for a while or about 10 minutes into highway driving.
The symptoms are that under part throttle, the engine misses heavily.
If running at a constant speed, say with cruise control at 70mph, there is not apparent problem. But if I start to climb a slight grade and the cruise control, or my foot, starts to give slight part throttle... the engine will miss and buck. If I give significantly more throttle, I can "push" through these misses and the engine will smooth out. "Flooring" the throttle will also force it through.
Similarly, if I am idling for a while and get the engine good an warm, when pulling away under part throttle... say pulling away from a drive-through or into traffic from a parking lot, the engine will miss and buck. Again, giving heavy throttle will usually smooth it right out, but not always.
I took it to a local shop a few months back and they did say they measured/observed problems from the distributor output when the engine warmed up under these situations.
So a few questions:
1) Is the optispark bad, or going bad?
2) Can the optispark be fixed (cleaned?) in place?
3) Can the optispark be cleaned or repaired without buying a new one?
4) Could this be another problem that is causing the optispark to have issues, or appear to?
If I need the optispark replaced, I know it is expensive. I also think I recall that Delco no longer makes them. Knowing that, I don't mind spending more for a better aftermarket unit that is durable. What make/model optispark is recommended?
Thanks,
Al
So a few questions:
Thanks,
Al
