FSUDAL
- Jan 8, 2024
- 2010 Buick Lacrosse CXL AWD 3.0L
I have a 2010 Buick Lacrosse CXL AWD 3.0L that drips oil between the engine and transaxle. The valve covers were leaking, which I changed, hoping that it would also resolve what looked like a rear main oil seal leak. Unfortunately, it has been a month since the valve covers were changed and it is still dripping between the engine and transaxle leading me to believe I also have a rear main oil seal leak. I tried ATP stop leak which did not help. Knowing how big the job is, I went to a local junk yard to practice using a three point engine brace. The junkyard car looked to have the same leak. After separating the engine and transaxle I wasn't sure if the leak was from the rear main seal, the corners of the rear main seal retainer plate, or the oil pan (see attached picture 1). As you may know the rear main seal come with a retainer plate (see attached picture 2).
Do you think replacing the rear main seal/retainer plate will solve the problem? According to the service manual, trying to remove the oil pan will also require that the timing cover plate be removed. That would be an absolute nightmare since I am not dropping the engine and do not have a lift at home. Where do you think the leak in the picture is coming from and how do you think it could be repaired?
Thank you.
Thank you.
