David Dietz
- Oct 23, 2023
- Sarah330EtGa
Thanks for letting me in the group! Okay here we go. 2010 Lucerne 60,000 miles, second owner. I have had it since 49,000 October of 22. Noticed a little hiccup at 55/60 mph about to weeks ago. No engine light. Rough idle. Drops down to 400 sometimes. Before and after I threw parts at it. New coil,plugs,maf sensor,map sensor,purge valve. I also tried a new throttle body assembly. I drove it a few hours and no change. I installed the volt meter tested original throttle body. I replaced the file pump relay. The old one was a little crispy. Took it to the local mechanic shop that's the towns folk swear by and the sprayed throttle body cleaner, changed the air filter and charged me $111.00. So I'm about $500 into this. It's my fault for throwing parts at it but I am at a loss. PS. The shop said it is not a vacuum leak. I am at a loss. And why only at theat certain rpm range? Thanks for your suggestions and comments in advance.
