Starting running issues
rayray61
04 lesabre
So I have an 04 lesabre. Replaced coil packs wires and icm. It starts but it's rough and does not stay running. Throws 0300 code any ideas
Check your spark plug order. Very easy to mix them up.
New plugs new ignition module new wires code p0300 but it seems like it's gets worse when you accelerate but when your at a certain consistent speed it's ok
If your plug wires are original they will be numbered. If not then I would suggest numbering them with a little piece of masking tape. Front bank is 1-3-5 and rear bank is 2-4-6.
Skip the dielectric grease on the coils. If and when you change spark plugs you should put the dielectric on the inside of the spark plug boots but not on the terminal itself.
Please name the brands that you used for ICM , coils and wires.
If you used quality parts then another culprit could be cracked porcelain on one or more of the spark plugs.
