I'm having the exact same issue with my 2012 Lacrosse. I've been searching for an answer to our issue, but with no luck. I know this has happened to me a couple years ago, and the dealer "reprogrammed" the switch I believe. Did you ever get a solution to the issue? Thank youI have 2013 Lacrosse. The sunshade works, the sunroof doesn't. I tried the reset method, not sure what else needs to be done. Both fuses seem good. Any suggestions?
I haven't checked the fusesI have 2013 Lacrosse. The sunshade works, the sunroof doesn't. I tried the reset method, not sure what else needs to be done. Both fuses seem good. Any suggestions?
