teves abs system
mrgriftmore
Hello, new to board.
Has anyone ever switched this system over to a vacuum system? I had my mechanic switch my Grand National over many years ago. The GN has a similar system which incorporates an accumulater ball and so on. He got it off a bone yard regal and I've never had any problems. He did have to swich out brake pedals as I recall. Any feedback would be greatly appreciated. Thanks
I'm asking myself the same question.
the ABS Power Brake Pump is cycling constantly and I need to replace it.
I suppose as long as the master cylinder will fit the booster correctly it would wourk. you would just need to get one with 4 fitting openings, or have slitters on each port.
I might try it if I can't find a replacement Pump for the Brakes.
It has been done, using same-year Riviera parts. (ABS was optional in the Riv at the time.) But it also entails refitting brake lines - including running a new one to the rear.
gtxbullet: your problem is probably a bad accumulator.
