JimP
- Jun 19, 2025
- Lesabre Custom
I get this code randomly now. I clear it and it goes away for a week or so but comes back. Seems coincident with a cold start.
I borrowed my friends scanner which exposed PO171 lean fuel mixture. Long term mixture advises limits of +/- 25%. I think this implies a ratio. My engine reads 14% idling. If I step on the gas it drops to around 0%.
The question I have is what is in the denominator vs the numerator. Is it fuel/air or air/fuel?
Considering the percentage drops when I rev the engine and (give it more gas) I would assume it is air/fuel. Apparently the amount of gas equals the amount of air when stomping on the accelerator pedal. Lotso air and little fuel at idle means it's lean and is illustrated by a bigger percentage.
Am I thinking about this correctly and is 14% on the high side?
I think I should be checking for air leaks at the intake and fuel pressure overall.
BTW a service guy changed the fuel filter because he observed it was leaking about two months ago back when I didn't have the problem ironically.
