the wife's '06's stereo won't change channels and the clock is not appearing. help.
showme
2006 Lacrosse
I did a search and thought I'd found the solution, but they didn't work. The first option was to hold the power button on the stereo down for 10-20 seconds, but that didn't work. Second option was to disconnect the battery, which I did and had it off for about 5 minutes to clean the post and clamp, but still nothing. Has anybody had this problem before, and if so, how'd you fix it? Any comments or ideas will be greatly appreciated. (Forgot to mention that the station can still be controlled by the tuning knob and the steering wheel controls. But the pre-set buttons for stations don't work, and the clock isn't showing up even when I try to reset the time with the H and M buttons.)
