Thermostat housing gasket
2000ltd
Daytona Beach Florida
2000 Lesabre Limited
Is it needed to replace the thermostat housing gasket, not the gasket on the thermostat itself, when replacing the thermostat?
Just use the tapered rubber gasket that wraps around the thermostat itself. I have never had to use a paper gasket on the housing.
I replaced my t-stat a couple weeks ago. There is a slight seepage at the mating surfaces, which is what led me to replace it in the first place.
I used the rubber-ish O-ring that came with the new t-stat. Since there was no gasket for the mating surfaces, I didn't think to make one. I wonder if I should disassemble it, add some RTV, and put it back together?
I looked for a fel pro or similar gasket for it and couldn't find one but I noticed if buying the actual tstat housing it comes with one. Hmm
Did you install O'ring gasket in the correct replacement way? If it is basackwards, it will leak!
I looked at the O-ring and did not see any obvious signs to install it one way or the other. I guess it would be good for me to crack it open and inspect it, eh?
Before I do, can you share some insight on how to determine the correct orientation? I saw no instructions with my t-stat so I concluded that it was reversible. Maybe not!
Mine was already installed on the thermostat I can send you photos of it later tonight if you want? I'm assuming they put it on the right way
Hoo-boy. I think I'll set aside some time this weekend...
The thermostat would not sit flush if the tapered gasket was installed upside down.
Take a look at the GM Genuine. The seal is installed correctly.
