The car lovers social network
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Buick parts & accessories
Advertise with us!
Advertise with us!
Torque Adapters are a tool used with air wrenches, where the air wrench is capable of much more torque then the specified wheel torque ratings. If they use the right adapter, it should be OK. The adapters are usually color coded, so they know the correct torque when they remove them from the box.
What is the torque spec for the axle nut on a 2010 Lacrosse. I can find 184 ft/lbs but that seems like a lot. Any other numbers out there?
OP said axle nut, not wheel nut. For the front, 184 ft lbs is correct. Actual procedure is initial torque to 111 ft pounds, then back off 45 degrees, then re-torque to 184 ft pounds. (110 for the wheel nuts is correct)
still sounds high to me for the axle nut, I wonder why the OP needs to tighten the axle nuts...
I'll bet either he changed the hub and bearing assembly or the axle/CV joint - neither is uncommon.
The axle nut is a self locking design, so the torque spec is important, but likely not critical...it just needs to be good and tight
