Displayhawk
- Mar 13, 2022
- 2019 Buick Regal Sportback
I found this article on the LubeGard website about 8-speed GM automatic transmissions. I have used LubeGard Platinum Transmission Treatment on previous cars I have owned and never had a problem with the transmissions. I was also going to upload their catalog, but it is too large for the server here. If you go to the LubeGard website, you can find it. For the record, I have absolutely no connection to LubeGard other than as a customer.
I apologize if the files won't open! I have copied and pasted the text below.
General Motors has issued several technical service
bulletins pertaining to torque converter clutch
shudder issues in two of their 8-Speed transmissions;
8L45 & the 8L90. This problem currently
affects 11 different models across 3 different OEM
manufacturers between the model years 2015 and
2019. GM’s solution to this problem is lengthy &
complicated, requiring 20 liters of ATF be flushed
through the system to replace as much fluid as
possible, yet still has not corrected the issue in some
cases. With these vehicles approaching the end of
their limited powertrain warranties, you can expect
to see an increase of these vehicles in your shop.
We're here today to offer you a better,
less complicated, and less expensive way to
service these transmissions successfully with fewer
comebacks and customer complaints.
We used our state-of-the-art Falex Multispecimen
testing platform to develop conditions that caused
shudder to occur between an automatic transmission
friction plate and steel plate when lubricated
with GM's recommended ATF specified in their
technical service bulletins. We then eliminated
the shudder under the same conditions by adding
Lubegard Platinum High-Performance ATF
Protectant to the test ATF at the treat rate of 2
fluid ounces per quart. An added advantage of the
Lubegard Platinum High-Performance ATF Protectant
was control and stabilization
of the friction
at a constant level throughout the tests.
When your customer is suffering from
TCC shudder and/or slippage, you can help
them avoid the expensive replacement of their
OEM ATF by simply adding 2 bottles of Lubegard
Platinum ATF Protectant, or, if the customer
insists on replacement, you can avoid recurrence
of the TCC shudder with the addition of 2 fluid
ounces per quart of Lubegard Platinum High-
Performance ATF Protectant.
of the friction
