dboud888
- Jun 12, 2025
- 2021 Encore GX
Car will shudder and engine will not rev and sometimes die when shifting from Reverse to Drive after startup. Performs fine in Reverse and if foot is held on brake in Reverse and engine is revved, everything is fine when shifted to Drive and car will operate normally until shutdown. Brought to the dealer several times but no code and found nothing while still under warranty. Last trip to dealer it now "Needs a new transmission" and it is now "Not under warranty - $6500.00." Still using the car as is and drives fine after the revving in reverse trick. I think it is a solenoid or senser or similar. Anyone else have this problem?
