Buickregal1995
- Sep 8, 2022
- 2016 Buick Regal
I have a 2016 Regal FWD with just under 40K miles. I bought it with 8K miles back in 2019 and it initially drove flawlessly.
In the past few years, I've noticed the trans has been randomly acting up at times (shuddering, delayed shifting, pre-mature shifting, slipping, and everything in between) and seems to be progressively getting worse. I have noticed when it is cold and wet outside, it seems to be mostly fine. It tends to act up the most in the warmer weather (70 degrees and up).
Some drives it might act up once and other drives every few shifts feel off. When I brought the tech from the dealer on a test drive, they felt it once, but said it could be a normal characteristic of the trans and sent me on my way. I've read several forums about how the transmission learns shifting patterns based on driving style so I asked to dealer to reset the computer to see if that would help any (hasn't seemed to make a difference).
The most common instance where I can get it to act up is if I am slowing down and speeding back up (think stop and go traffic). When re-applying the gas, I'll hear the sound of a metal plate engaging and will experience a shudder. Typically after the shudder, the next few shifts in a row are very awkward (slip/delay/pre-mature shift) until it is fine again. I can even be on a very flat straightaway with cruise control set at 45MPH and will sometimes feel a random shudder/slip (RPMs seems to stay the same when that happens so it's not like it's trying to up/down shift).
Only other thing worth mentioning is about a year ago I popped the hood for something and noticed seepage around the trans reservoir cap (picture here). When I showed the dealer, they said that some seepage can be normal depending on temp outside and "other characteristics" and sent me on my way. Dealer has extensive notes from when the vehicle was still under warranty and said they'll get it covered only if they can duplicate and find something wrong.
Help!
Help!
