Turn signal acting up
Mar
1994 Buick roadmaster
My left turn signal work perfectly front and back but my right is weird, when I put my right on to turn it just lights up solid no blink but it work regularly if I put my hazards on (makes no sense to me), my taillight on the right also glows brighter than the left with the running lights on and when I brake, I do have the front right lense cover missing (plan to grab a whole turn light assembly from another roadmaster) so it it’s open to water and things, I’ve been told it could be solved by just changing the bulb and also that I need a new turn signal switch, I thought someone on here might be able to help more
What lights up solid on the right, the dash indicator or the front or the rear?
They use dual filament bulbs, the hazard and brake may work and directional not if one filament is burnt out.
Did you check the bulbs?
The dash indicator, the front and the rear light up solid and I swapped the front, im just gonna swap every bulb front and back to make sure, is it possible the housing for the front is messed up because it doesn’t have a lens cap on it
That is a strong possibility, if there was no outside lens on the indicator.
It’s crazy I guess the filament bulbs weren’t in properly it just took for someone to switch the position I guess and it was back to working properly😂
