Parkavenue95
- Apr 7, 2019
- Park Avenue
Alright, I'm at a loss. I drive a 1995 Buick Park Avenue VIN K, with just over 100,000 miles. The MIL is illuminated with code P0361 (Ignition Coil K malfunction). There are no other codes or misfire codes specifically. Now to my understanding, Ignition coil K means cylinder 11. I've been looking all over my V6 for the 11th cylinder!!! (Joking). Is there any reason this code would pop up, especially since the Park Avenue was never made in a 12 cylinder model? I'm curious why the computer even knows that code. Has anyone experienced this? I haven't noticed any symptoms. No stalling or bad starting. No rough idling. No extra fuel consumption. I haven't run too many tests yet, but have used an In-line spark tester to verify that each coil pack IS producing spark. Whether it's enough spark, I dont know. But there is spark. Spark plugs all have the correct gap and do not appear worn. They look fairly new. I'm not sure what is causing the MIL. Somewhere i read crankshaft position sensor? Thoughts?
