msnott
- Apr 11, 2022
- Danville, IN
- 2004 Buick LeSabre Limited Celebration Edition
I own a 2004 Buick Lesabre Limited.
I have noticed that when I am at idle, my heat is lukewarm. When I am driving and the RPMs are up, my heater’s air temperature rises but is still not what I would consider hot. My coolant level is and has been normal.
What I noticed was that my coolant temperature ranged from 178-185, never climbing above the 185 mark. Is this the reason for the lukewarm air temperature from my heater? Should the coolant temperature be more like 195-205 in order to provide hot air?
I also suspected a blend door issue, but I do hear the whizzing of the blend door when changing the digital temperature control from a/c to heat. Whether it is fully operational, I do not know. All I know is that I hear the whizzing and it does change from a/c to heat, even if it is only lukewarm heat.
I have ordered a new thermostat, but don’t know if it is the solution or if I should continue diagnosing the problem.
Any help is appreciated!
