Are you having "ground" related issues?Where is my ground strap? 99 Buick lesabre
Yes car starts but uf I touch the power windows to roll down the car diesAre you having "ground" related issues?
Get your battery load tested at AutoZone or O'Reillys. They will also test to see if your alternator is charging.Has anyone solved this ? Having same issue if I touch the windows buttons car dies alternator ? Battery ? Lights flicker a bit car was sitting for a while. New pump and still happens
The main ground is the negative cable of the battery, but there are countless grounds throughout the car. Loss of one can create weird symptoms. If you do not have a factory service manual, fixing your car can be an exercise in futility and aggravation. Search on Ebay, the FSMs are frequently very cheap there, but they are priceless for diagnosing problems.Has anyone solved this ? Having same issue if I touch the windows buttons car dies alternator ? Battery ? Lights flicker a bit car was sitting for a while. New pump and still happens
What new pump?Has anyone solved this ? Having same issue if I touch the windows buttons car dies alternator ? Battery ? Lights flicker a bit car was sitting for a while. New pump and still happens
