Where is power steering located
z.a.o
I have a 99 buick regal with sc engine. I can not seem to find where the power steering is located so I can chec it. Is it under that plastic cover over the engine or somewhere else. Please help.
Z.a.O
If you have the 3.8 it is between the firewall and engine below the alternator. Locate the heater hoses where they connect to the firewall and you're close. It is not easy to find if you don't know where it is because it is low down and hard to see and access.
Do not check the fluid level while the engine is running if you plan to continue using your arm.
