Wood door trim removal
Pirate Pete
Park Avenue owner
Las Vegas
2001 Park Avenue Base 3800 series II with Bridgestone Advantage tires accompanied by Buick mudflaps
I have a 2001 park avenue base and the wood trim on the dash is dull. I wanted to remove it and spray it with clear gloss so it is shiny again . I know the trim on the dash comes off easily . Can I remove the wood trim from the doors as well or is it not removable ?
If you are referring to the wood trim around the door switches, then yes, the panels pop out since the switches are mounted to them.
Pictures would help so that we're all talking about the same pieces.
Yes , the wood trim around the window switches on the doors . Thank you for your help .
