S1L1SC
- Dec 23, 2010
- Buick
I have looked through some of the older threads, but can't find anything conclusive.
Here is the problem:
'91 Roadmaster Wagon.
Car runs and idles fine when it is cold. Once the car has been running for a while and the engine is up to operating temperature I run into the following issue:
When I stop at a traffic light the car goes into idle ok. But after a little while the idle starts surging. The needle starts jumping up and down and the variation starts getting worse the longer the car sits. After a while the engine will "stumble" and cut off.
From my research it seems that it could be the Ignition coil, Idle sensor of Mass Air Flow Sensor. Since the car only does this when the car is warm, I am wondering if I can eliminate the sensors?
Anyone have any idea what else it could be? Vacuum leak somewhere?
Thanks for any help guys!
