The way the system is supposed to work, there is a compressor check every time the ignition is switched on. After a 17-35 second delay, the compressor should run for 3-5 seconds. It should run to adjust the height when needed after that. The relay for my car was under the rear seat. I found which one it was, and removed the plastic cover from the relay. I could actually use my finger nail to manually trip the relay, and the compressor would run. I'd do that until it raised the rear of the car. It leaked down in a few days, but until I was able to troubleshoot it properly, that is what I did. You should find out what the trim height for the rear of your car should be and measure it. The pictures make it look just a bit low, I think.
