The car lovers social network
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Buick parts & accessories
Advertise with us!
Advertise with us!
We just got a 2008 Lucerne, and the first time I shoved something into the back of the trunk it snagged a harness that was hanging low. I tucked it up, but am now resolved to go back under there with a handful of long zip ties and take care of all the harnesses and wires that may be unsecured.... On another forum a posting said that he found a loose wire in the trunk between the two speakers. I looked there and saw a device with a wire connection. It was not loose, but when I unplugged the wire and replugged it, my remotes immediately worked again.
Several years after your post I had the same issue today with 2 fobs not working. Unplugged and plugged connection in trunk, fobs are now working. Thank you!I had the same problem. Both my remotes stopped working at the same time, so I was rather sure the problem was the receiver and not the remotes. On another forum a posting said that he found a loose wire in the trunk between the two speakers. I looked there and saw a device with a wire connection. It was not loose, but when I unplugged the wire and replugged it, my remotes immediately worked again.
i tried this and it worked like a charm...thank you soooooo much !!!!!!I had the same problem. Both my remotes stopped working at the same time, so I was rather sure the problem was the receiver and not the remotes. On another forum a posting said that he found a loose wire in the trunk between the two speakers. I looked there and saw a device with a wire connection. It was not loose, but when I unplugged the wire and replugged it, my remotes immediately worked again.
Thank you so much, Jesus has it to work for me too!🤗i tried this and it worked like a charm...thank you soooooo much !!!!!!
Had the same problem the day we packed my 2009 Lucerne to leave for the weekend. FYI...the loose wire is at the front (nearest the backseat) of the trunk. Once I knew what to look for it took < a minute to fix.I had the same problem. Both my remotes stopped working at the same time, so I was rather sure the problem was the receiver and not the remotes. On another forum a posting said that he found a loose wire in the trunk between the two speakers. I looked there and saw a device with a wire connection. It was not loose, but when I unplugged the wire and replugged it, my remotes immediately worked again.
Where is the fuse located for the alarm?I'm having the same problem with my 2006 Lucerne. I tried to reset by pulling and replacing the fuse, but when I try to relearn remote keys, instead of giving me an activate label, it just blinks once and goes back to the same screen. Maybe I'm pulling the wrong fuse (display).
I also heard it can be the ignition switch. I'll have to look into getting one. They are pricey though. Thank you for the input.Here's the diagram and fuse location, but no listing for alarm. Also that post is from 2011 and the poster has not been back.
On some vehicles a soft reset is done by removing both positive and negative battery cables then touching the ends together more details on line on this method.
Not sure if any of this will correct your problem if it's the ignition switch itself but worth trying I guess.
Both my tire monitoring system and can you remote stop working over a year now and on put I new fuse in and it’s back to working it was fuse 35 10 amp good lucktried unplugging wires, pulled fuses, etc. still no luck. tried reprogramming, no luck. replaced device in trunk, no luck. noticed that now the tire monitoring system has given up too. Any suggestions?
Where is this fuse located?Both my tire monitoring system and can you remote stop working over a year now and on put I new fuse in and it’s back to working it was fuse 35 10 amp good luck
