The car lovers social network
Automotive Hot or Not
Vehicle hacker protection
Advertise with us!
Explore Pet Insurance!
The Food Order Method
Buick parts & accessories
Advertise with us!
No photo, sorry. But it is about 4" behind the opening in the cover.
I watched the dealer tech change the oil once, it was a disaster! The oil drains out all over the top of that cover. It took him longer to clean up than actually drain the oil!
Somebody slept through the design of that cover, it's in a horrible spot and the cover is too big to remove for this (should be) simple procedure.
The best engineering I saw was was done at the dealership, when I came back for the next oil change they had devised a sacrificial Verano-oil-change-funnel/pan-device to channel the oil over the cover. 🙂
Why was the plastic there in the first place? Is it protecting something?
Brought my own oil - Valvoline full synthetic SYNPOWER 5w-30 (exceeds dexos1 specs) 4.73 litre container on sale for $22.98
Use only engine oil licensed to the dexos1® specification, or equivalent,
of the proper SAE viscosity grade. ACDelco dexos1 Synthetic Blend is
recommended.[/QUOTE]
I've been reading some oil discussion on other forums about the dexos1® spec. Note that the owner manuals to use _oil licensed to the dexos1® spec. If it meets dexos1 then why does Valvoline put the Dexos approval on the front of the bottle. Saying that it "exceeds dexos1®" means nothing. Does it exceed one item of the spec or does it exceed two items?
I'll look for the Dexos approval on the bottle if I end up buying a GM vehicle in the next few months.
http://www.gmdexos.com/licensedbrands/dexos1licensedbrands.html
Well I certainly prefer cutting a piece out to putting a fire out 🙂
FWIW the owners manual seem to disagree with you.Licensing a product increases the price to the consumer. Valvoline is not playing that game with GM. I am sure other companies aren't either.
You don't even have to put in dexos1 spec oil, you can use oil with the api starburst symbol with the correct viscosity as well. It may just give your vehicle reduced performance in some circumstances.
http://www.valvoline.ca/promos/dexos.jsp
http://aoca.org/resources/have-questions-about-general-motors-dexos
Notice: Failure to use the
recommended engine oil or
equivalent can result in engine
damage not covered by the
Vehicle Care 10-11
vehicle warranty. Check with your
dealer or service provider on
whether the oil is approved to the
dexos1 specification..
Can anyone tell me if this is the location of the oil filter? If not can someone tell me or show (pic) where it is? Thank you.View attachment 4408
The engineers who designed this car should be drug tested.did my first oil change today and sacrificed a pizza pan,cut and bent to funnel the oil into the catch pan.why would anyone not be thinking ahead to do a oil change is mind boggling.No photo, sorry. But it is about 4" behind the opening in the cover.
