95 park_avenue
- May 8, 2013
- Buick
hi Im new here. been searching around for the issue im having and havent found anything too specific. Anyways I started having my brake light and the dinging come on when the winter cold weather came. It would come on only below 32 degrees, and anything above the brake light wouldnt come on. Well it started coming on more when it was cold and eventually just always goes on. The dinging is the most annoying part. Now it is warm weather and is still on all the time. My car only has 70k miles. I just had a lot of work done. Had all the intake gaskets replaced. lower and upper and the upper plastic redesigned manifold. Also had that new design pcv stove top as well, and the water pump and spark plugs replaced. switched over to synthetic. The car runs like new and this brake light is really getting on my nerves. When I searched i saw people saying there are switches on the brake pedal assembly that will disconnect the dash light. I tried looking around the assembly. I found some sensors and tried disconnecting them with no success. Anyways Im just looking for some help. thank you.
