OEM Brembo Brake Pad Replacements - On Backorder
Wind_Stu
I currently require the front brake pads on my vehicle to be replaced. My local GM dealer in Canada is unable to locate any OEM Brembo brake pads.
I have luckily found a dealer in the US that has some in stock. However, he has told me that the front brake pads are on back-order in the US as well. I simply got lucky.
Just a friendly warning to everyone in case you would like to replace your front brake pads with OEM equipment.
The OEM front Brembo Brake Pads have a GM part number of 13329562.
I find it very disappointing that GM does not have brake pads (a wearable part) readily available.
Try www.newgmparts.com for OEM or Rockauto for aftermarket. I live in Canada , I just bought replacement at Autozone in the states for 49.99 and they work great. The pads are for 2009 pontiac g8 gxp. They are the same pads. Good luck
I agree. Have those pads on my G8 GXP front Brembo's (same as GS) and they work great. Quiet, much cleaner (a little light brown dust) and stopping power that is close to OEM pads.
