Some quick items i found this weekend.
The rear sway bar on the 2003 Gran Touring (F41) was 18mm
(used an 18mm open end wrench to measure)
and is part number 25604731.
This went on in almost no time at all. Maybe 1 hour counting time to jack both cars up. All the body mounting areas were all threaded and the rear A-arms had the end link holes in them. The only issue I had was the end link nuts were VERY large. Had to use a crescent wrench to hold them as I did not have a socket or an open ended wrench to fit.
Now the front was another whole story. Using the crescent wrench as my precise measuring device, the F41 was only slightly larger; but I did not have an open ended wrench big enough to measure it exactly and the tag was faded-so no part number. So I decided to swap that over as well. Boy what a job! ...and messy too thanks to a rear valve cover leak.
For starters, (according to the service manual) you have to disconnect the left tire rod end and the exhaust down pipe. Then the bar has to be snaked out the left side. Since it looks like a huge, greasy, cork screw and the space is small and cluttered, it was a bear to remove. Even with no engine in the parts car, it was not easy to remove. Since it is going to the junk yard soon, it will NOT be re-installed.
However, once the Gran Touring bars were installed into the 01, it's a different car. Handles curves with confidence and does not want to capsize at the smallest turn of the wheel. It is still VERY floaty as far as ride goes, so the next project will be new struts/shocks and spring swap.
So to answer your question, rear bar is easy-front bar is not.
