suprnova74
- Sep 10, 2015
- Buick
1997 buick century Limited odometer reads "Error" Gear shift "2" lit up
my daughter's 97 buick century limited had a power failure due to a loose battery ground which was found after a jump start. after i tightened the cable, she noticed the odometer reads "rErro" (Error i resume) with a square orange 2 highlighted. I took it to autozone just to test the batter and see if any codes were tripped. no codes were readable from pcm and battery tested fine. he suggested to disconnect the battery, turn ignition on for 30 seconds, and reconnect, start car and let run for 30 seconds, then see. no luck. someone suggested pulling the cluster fuse again for 30 seconds, no luck.
I also noticed the temperature display is now in Celcius and cannot find a way to switch back to Fahrenheit.
Any suggestions on getting this reset/fixed? I don't have easy access to a tech 2 scanner to see if it's something in the other modules. i hope it's not a fried cluster or bcm. this thing has unfortunately been a money pit since we bought it and i know both of those aren't exactly cheap considering the age of the vehicle.
Here's a pic of the error message:
http://i.imgur.com/VgDVZOn.jpg
